Discuss Please help me diagnose these drips and condensating pipes! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can you post a picture of the controller?
Of course - please see below:
It looks to me that you have some kind of heat recover and humidity control system. Is there any equipment installed outside The property?
sounds like air source
Reply to Please help me diagnose these drips and condensating pipes! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hiya - posting in this forum as I'm guessing this relates to my neighbour above's boiler, but I may be wrong so please say if so. Basically the...
Hi, I have a PRV located in a heated plant room that is between a pair of stop cocks. It was installed to keep pressure under 3 Bar a couple of...
We had water leak from the laundry sink into the cupboard below, then flow down the hole cut for the pipes (the hole was on the floor of the...
James Auberon
J
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
