Discuss Please Help to Identify Brass Fitting in the USA area at PlumbersForums.net
I have a vintage tank with a tapered brass fitting fixed in.
A new mating fitting is required.
The thread is 7/8" max with 26 tpi and it is tapered.
7/8" 26 is a standard British Standard Brass (BSB) thread, but tapered?
I can find no reference to BSB tapered.
Help?
Nearly all old BSP fittings are tapered thread most new ones are parallel as easier to manufacture. Is the fitting a bush to allow to Reduce to smaller fitting
I assume it was a blanking plug which had been drilled for a pipe to be sweated in. It is now damaged beyond repair.
Reply to Please Help to Identify Brass Fitting in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached...
Sebastian T
