Discuss Plumber needed to fix pumped shower in Westcliff-on-sea (South Essex) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PaulR
I have a pumped shower that has stopped feeding water from the hot inlet. Hot water is getting to the pump, but not to the shower. Already replaced the pump, but no dice. Also swapped the inlet pipes over and now I get hot but no cold. I'm thinking it may be be the mixer valve in the shower, but I'm no expert. Would appreciate an experienced and reliable plumber to have a look. Thanks.
Paul
Paul
HI
I live in Southend on Sea could call in and see you Monday
regards
Reply to Plumber needed to fix pumped shower in Westcliff-on-sea (South Essex) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
