Discuss Plumber Qualifications Query in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi. I have an elderly neighbour getting quotes who has asked for my help and opinion, I don't really have a good one as it is not my area of expertise but I am trying to help.
The quotes are all similar prices but She seemed to like one person and quote more than the others and I noticed that was the only one with qualifications listed on the quote, so I googled them a bit but there are lots of plumbing qualifications. I wondered if I list them here anyone familiar can advise if they are real or not please as I don't want her to make a bad choice.
City & Guilds Lvl 1&2 Domestic Plumbing and Heating (when searching this I can see the official website with NVQs up to Lvl3 so I guess they are up to an NVQ Lvl2?)
City & Guilds Bathroom Design & Installation (when searching this it just brings back the same official website search results as the Lvl 1&2 Domestic Plumbing and Heating. Maybe it was separate before but is now part of the 1&2 I'm not sure?)
BTEC water Regulations (when searching this I couldn't find a BTEC, but I could find a BPEC organisation. Are they the same and changed names if anyone knows?)
BTEC Unvented Heating Systems (when searching this I couldn't find a BTEC, but I could find a BPEC organisation. Are they the same and changed names if anyone knows?)
Thankyou. Hope it is ok to ask here and someone is able to advise
I'd be asking to see previous work.
What sort of job are we talking about?
Qualifications are by no means a gaurantee of good work. Likewise the other way round.
Yes I agree. My neighbour is getting quotes to have her quite old bathroom ripped out and refurbished to bring it up to a modern look along with accessibility options of a walk-in bath or a shower with a folding seat to keep her independence as long as she can.
When She asked for my advice I looked at the quotes which came with photos of previous work, some of them had websites with a gallery also and they all looked to me much of a muchness as I kicked a few tyres whilst listening to her. What got my attention was she also said this one plumber had said he will need to move or refit the shower pump as it had been fitted directly to the Mains supply due to her system being an Unvented system.
I did some reading on that and took a look in her house, she has a cold tank in the middle of her loft filled by a Mains pipe coming up the corner of the house and across the loft to the tank. Then the cold tank has a pipe that goes down the middle of the house to a downstairs cupboard and it connects into the shower pump which is housed there, along with a hot water storage tank filled by a normal boiler (not a Combi boiler) and this hot water tank has a pipe coming out of it and into the shower pumps other connector.
Other than cupboard/tank locations, that is a very similar set-up as I have in my home as well which I am certain is not an Unvented system unless I misunderstood my trusted plumber from many years ago who installed mine?
I have tried ringing my plumber but I got the answerphone that he is on holiday for another few weeks, I have told my neighbour that I will ask on the forums for her for now and also I will ask my plumber to come and give her a quote when they are off their holidays as I've always found them fair priced and have been happy with their work.
You need to confirm that the unvented cylinder is actually plumbed in as an unvented. You can use them gravity.
You need to confirm how the cylinder is fed. Is it fed from the loft tank? Or mains? I suspect, loft tank. Turn off the main stock cock so that the kitchen sink has no cold and the ballcock on the loft tank does not refill the tank. Then run a hot tap, this will tell you if the unvented is mains or tank fed.
If it is loft tank, then pump is fine. Either move pump or convert to mains. Need to check water pressure and flow rate before making that decision. Unvented cylinder will need to be commissioned by someone qualified (all safeties need to be checked/ensure prv and discharge line are installed).
If it is mains, then loft tank should be decommissioned and supply/outlets linked/pump removed.
Hi thanks. I went and took another look. In the loft there is a cold tank which is covered with a lid. It fills from the mains as I turned off the Mains pipe where it came in the house and soon the kitchen taps ran dry but the bathroom taps did not?, I got her to flush the toilet also when I was up in the loft and the tank wasn't filling by the sound of it and when I had reopened the Mains I could hear the water hitting what was in the tank already just standing under the loft hatch before going back up.
The Loft tank had some pipework going down into the house.
The bigger pipework comes down into her hot water tank cupboard and goes into this tank near the bottom. Just before the tank it does joint off to a slightly smaller pipe that goes into the shower pump. There is a blue rubber handle on it which guessing is to stop the flow as there is one on the opposite pipe coming out the other side of the shower pump, which has 4 connections in all. These 2 blue ones and another 2 red handled ones.
There are other pipes feeding in/out of the hot tank and on the wall where they run up they have faint marker pen saying "to shower", "cyl return", "main flow" and a few others I can't remember.
This hot tank has a pipe coming out of it connecting into the shower pump and is 1 of the red handled pipes. The other pipe coming out the other side of the pump is the 2nd red handled one and goes up the wall and is the pipe marked "to shower".
The hot tank didn't have a brand name I could see but the shower pump had Monsoon on it.
Her hot tank looks to have a backup mains heater in case of boiler failure as near the top of it is a black cap that says "Do not cover, disconnect from mains before removing" and then it has a lead and plug coming off it into a wall switch which is currently turned off.
The other cupboard nearby has her boiler in it and looks like a normal boiler. It has a couple of big copper pipes going in/out of it and I saw the brand looks to be Worcester and the model was Greenstar Ri and some numbers I've now forgot.
I don't think she wants to convert any of this as she said she had the boiler replaced and the hot tank moved from a bedroom to this cupboard about 7years ago, she is just wanting her bathroom removed and redone and I don't want her to make a wrong decision on it. The designs she does have it basically looks like removing what is in the bathroom and redecorating with paint and tiles then putting new stuff back in roughly the same place depending if she goes with a walk-in bath or a sit-down shower but I don't see how the pipework will need to go anywhere different to where it is now whichever she chooses.
Their comments on the shower pump needing moving and the reasons don't sound right to me so I thought I'd check if these are standard qualifications they listed and if what they have said sounds right or a bit dodgy?
My reading of your description is that your neighbour currently has a traditional vented hot water system, with the storage tank in the roof supplying low pressure cold water to the hot water cylinder, bathroom and toilet. This is known as an indirect cold water system. The shower pump is fed from the low pressure cold and hot water tanks.
Upgrading to an unvented cylinder, which can only be done if the water supply to the premises meets the required pressure and flow requirements, would remove the need for the pump. It would also provide a direct feed to the basin cold tap, which is nice because people will probably want to use it for drinking water and cleaning their teeth.
If the vented cylinder is staying I'd want to run a direct (i.e. mains) cold feed to the basin tap and then on to the toilet as part of the refurbishment. I'm not sure whether the water regulations require this improvement but, as someone who once found a dead rat in a cold water tank, I think they should.
Looking at the course titles in post #1, I think it is likely that 'BTEC' is a typo. BTec qualifications do exist and are 'more practical and less academic' alternatives to GCSE's (Levels 1 & 2), A-levels (Level 3) and 1st/2nd year of an undergraduate degree (levels 4 & 5 respectively) these are not specialised 'plumbing' as such, they cover broader areas such as 'engineering'. BPEC, on the other hand, designs training courses for, inter alia, plumbing, which are delivered by training providers such as local FE Colleges. BPEC accredits these courses and their awards.
Thankyou for the detailed response. Based on what I've been advised here and taking a look with a few other neighbours now we think this 1 plumber is trying to pull a fast one with the shower pump works. They are both cheaper and more expensive than some of the other quotes which are all remove old bathroom, make good and decorate/tile the walls as well as put in a new sink, higher toilet, probably a sit-down shower now, 1 or 2 grab handles on walls plenty of space, swap the old radiator for a towel rail and put some new flooring down.
She said she had the pump installed years ago as the shower was very poor and she had started having to use the shower more than the bath so wanted the shower to be stronger. She needed a new boiler and hot tank so got the shower pump added in at the same time and she said she has not had any issues with either of them since and now just wants to have her bathroom made nice and more accessible for her.
Thanks to all who gave their time, me and her neighbours appreciate it ;)
From the OP's description, the shower pump sounds like it is pumping the cold from a distributing pipe that is shared with the cylinder feed. This is not good practice, so there is something slightly incorrect about the system. Am I the only one on here thinking this?
I wonder if we have a case of chinese whispers here in which the plumber suggested he might need to move the pump and has explained this in non-technical terms, or has used the terms incorrectly? This would not necessarily make him a bad plumber. I'm not quite sure how the plumber who mentioned the shower pump is pulling a fast one if his price is neither the cheapest nor the more expensive, though it would be desirable to know what he is proposing to do about the shower pump. Obviously if he cannot make himself clear, that may be a problem.
FWIW, I have the level 2 NVQ and I know, and just from my own college (private company owned by the local authority and therefore better than some private firms?) just how talented some of those I studied alongside were, yet how slapdash and lazy others were. I get the impression we all passed eventually, but, while there is quite a lot in the syllabus, you can pass by knowing very little.
Hello, you gave me some good advice on my other thread and noticed you had replied here. Is that a problem for my neighbour and is so how please?
I took another look and the cold tank pipe to the hot water tank is biggish, then the pipe coming off of it to the shower pump is a smaller diameter. I didn't have anything to measure exactly at the time but they are visibly different sizes.
Good catch. To quote the Stuart Turner installation manual:
"The cold water supply: Must be a DEDICATED AIR FREE supply via a tank connector, and must be positioned at a slightly lower level (25 mm minimum) than the feed pipe to the hot water cylinder."
I've always assumed that the "25mm lower" requirement is for safety; to mitigate a scalding hazard by ensuring that, if the CW store is starved, the hot feed to the pump is exhausted before the cold feed runs out. The Salamander CT installation guide, however, doesn't seem to include this requirement and the diagrams are inconsistent on this point.
Thankyou for this information.
So I went and took another look at my neighbours shower pump etc and apologies my eyes worked better today and I made a mistake on the pipework. I think the pipework is ok as per below, if I'm wrong please let me know
Here is what I originally reported
"The bigger pipework comes down into her hot water tank cupboard and goes into this tank near the bottom. Just before the tank it does joint off to a slightly smaller pipe that goes into the shower pump. There is a blue rubber handle on it which guessing is to stop the flow as there is one on the opposite pipe coming out the other side of the shower pump, which has 4 connections in all. These 2 blue ones and another 2 red handled ones."
The big main pipe has a blue handle valve on it, soon after that it the big pipe runs along the back wall and goes into the hot water tank down the bottom rear of it, and it also joints or tees off to that slightly smaller pipe I noticed.
I wrongly traced this pipe before and thought it went into the pump as it runs behind this pump and there is a lot of pipework in the cupboard at this point.
It doesn't connect into the pump, this little pipe joining off of the big cold tank pipe ends in what I know is a bleed valve to drain with a hose as my plumber has done it around mine before when replacing something.
It does not go into the shower pump. Sorry. The pipe ends in a bleed valve tucked behind the pump.
Looking properly at all the pipes this time and squiggling some down on paper, the shower pump has its own smaller pipe feed coming down the wall into it from the cold tank, there is smudged marker pen on it but it looks like it might once have said "CWT to Pump". I went into the loft and confirmed there were 2 different pipes coming down also.
The shower pump then has its other cold pipe going up to the shower, both of these cold pipes run side by side up the wall. Both have blue shut off handles soon after the pump.
The shower pump then has a hot pipe coming to it from out of the top of the Hot water tank and it goes into the pump, then the pumps other hot pipe goes up the wall next to the cold pipes going down from the cold tank and up to the shower.
The shower pump sits on the floor of the cupboard and according to its metal plate information it is a Monsoon Standard Twin 2.0 pump, I searched a bit and I believe it is a pump providing 2 bars of pressure to her existing shower?
As it sits on the floor and you mentioned some measurements I took a tape over. The pump is on the floor and has heavy duty flexicoil pipes which connect to the pipes on the wall/from the tank, where each flexicoil goes into the pump it measures about 400 - 420mm from the floor.
The hot pipe feed coming out of the hot tank is approx 1120mm in height from the floor and it runs shortly to a wall and then clips around the back wall of the cupboard at this height. It then comes down the back wall corner to a height of around 520mm and then comes over and around the cupboards sidewall (this sidewall has the majority of the pipework on it) where it then connects to one of the heavy duty flexicoils into the pump, and they all connect into the pump at around 400 - 420mm height.
Is that sort of in line with the 25mm you mentioned please?
Again sorry for the mistake but also I have enjoyed learning on this thread. Thankyou for your time and patience.
The 25mm height difference refers to the two tank connectors on the cold water store in the roof.
The Monsoon is a Stuart-Turner brand and the installation instructions are available on the web, e.g. for the standard model:
so you can compare what you see with what they recommend.
Thankyou for that link. Figure 3 on page 10 is pretty much the same as my neighbours pump setup so that's great thankyou again.
I understand now the 25mm you meant the 2 pipes coming out of the cold tank, I'm pretty sure the pump pipe was lower but I will re-check later on to be sure.
In brief, what he means is that the shower should ideally run out of hot water before it runs out of cold water to prevent all possibility of scalding temperatures to the person using the shower.
As for your question about the shared distributing pipe, your update suggests that the pump has a dedicated feed from the cistern, so all is well.
That's great. Thankyou for your help and advice
Reply to Plumber Qualifications Query in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
