Discuss Plumbing + boiler parts massive list in the Plumbing Jobs | The Job-board area at PlumbersForums.net
smtplumbing
Items for sale
Allright guys I am have a bit of a clear out, I have bit of old stock left over from jobs if there is anything you fancy make me a offer. Few items have been reserved for some members once payment has been received I will alter the list.
2x rolls 15mm hep02 25meter roll not barrier
Chrome fittings
5x bends kuterlite compression bagged
2x ballfixes
2x strights
3x bends kuterlite unpacked
9x chrome munson rings
Brand new McAlpine items bagged and brand new
44x 1”1/2 s traps TP10
20x 1”1/2 45 bends MT20
15x 1”1/4 bottle traps A10
26x 1”1/4 90 bends MS4
45x 1”1/2 tees
9x 4” 20mm Offset pan connector Mac4
3x 110mm grey boss strights with 1 open end boss and 3 closed end
20x solder 22mm tees
2x bag of 15mm sleeves hep02 50 each bag
1x magnacleanser drain down valve ( can use on 22mm pipe) as a drain down
310 plumbcentre end feed fittings brand new still in tub never going to use them
1x Vectraire 110 fan and transformer
Baxi 45o Bends Pair (135o) 60/100 includes potterton promax multifit
1x brand new mira sport 9kw shower white and chorme
1x brand new mira sport 9.8 kw whit and chrome old shape
AristonMicro Combi 65100248Main PCB Micro Combi 23/27 MFFI
AristonMicro Genius 11 999397Fan Ariston Microgenius 31
FerolliModerna Domina 80E43909039804890Expansion Vessel 8 Litres Moderna Domina 80E
Glow WormCXI HXI SXI44219220008020731Glow Worm PCB
Glow WormCXI HXI SXI 20020731Electrode
Glow WormCXI HXI SXI 20027897Interface PCB
Glow WormCXI 4421582000801831Plate Heat Exchanger
Glow Worm 4404422000802600Disconnector
Glow WormSaunier Duvall 51047000PCB PCB Thermaclassic F24-30E PCB
Glow WormCXI Ultra Com442273801666Glow Worm 8 Litre Expansion Vessel
IdealFF Classic104130 FF Flue Kit Classic
MysonApollo470720THORN4525468Fan Myson Apollo Fan Assembly Interpart
PottertonPowermaxP504 FAN481467Potterton Powermax Fan 135/140/155 CP Fan
Potterton 4528908929014Fan Potterton Puma 100-100E
PottertonUltra 24050729 451456 Fan & Mounting Assembly
Potterton/Myson 451456 PCB Potterton Ultra 2 Myson Apollo Range
VokeraCompact 2447809210020793Fan Compact, Option 24 Sabre 24
Vokera 5910Vokera 5910Fan Excell 80SP 80E, 96E
Vokera5963478710 Fan Mynute 10E
Vokera5271477013 Side Panel
VokeraCompact 29HE Various4780761005246Heat Exchanger Compact 29 HE, Linea Max Mynute 28 HE
VokeraMynute 20E 10021232Heat Exchanger Mynute 20E
VokeraMynute 10-14E 10021231Heat Exchanger Mynute 10-14E
VokeraSyntesi 25E 10025911Syntesi PCB
VokeraLinea 10024731Linea 729 Linea 730 PCB
VokeraCompact 10025340Compact 25HE, 29HE
VokeraMaxin8481 Maxin 24E, 28E PCB
VokeraUnica HE 10028558PCB
VokeraMynute8214 Ignition Control Box
VokeraMynute / Linea 10028891Flame Control
VokeraVarious 1005272Pressure Switch
VokeraLinea2905 Motorised Valve
Vokera 0975 Hoba Pressure Switch
VokeraMynute 10E - 20E R10029470Mynute PCB 10-14-20E Models
VokeraMynute Range R10021253Mynute Gas Valve 10-14-20E Models
VokeraExcell Range 0950 Elec Control Kit
VokeraMynuteR7791 Elec Ignition Control Box
VokeraExcell7097 Excell Ignition Circuit Board
VokeraMynute9800 Ignition Box Mynute 10SE
VokeraLinea Maxin 28ER6492478702Fan Linea 28
VokeraMynute 20E 10020839Expansion Vessel Mynute 20E
VokeraMynute SE & 1448478185R7620Expansion Vessel 10,14,205E & 1448 SE
VokeraMynute 10/14 E 10020840Expansion Vessel Mynute 10E, 14E
VokeraExcell4786985910Fan Excell 80SP 80E, 96E
VokeraLinea 10024558PCB Linea 726
VokeraLinea 10024528Linea PCB
Vokera 47817310025074Gas Valve Sigma Compact, Linea
VokeraMynute HE Range 20002906Full Pump & Housing
VokeraMynute SE Range478185Vokera 7620Expansion Vessel Mynute 10,14,20 SE
VokeraUniversal2359029 Vokera Universal Standard Horizontal Flue Kit
VokeraOption 24 Only Standard Horizontal Flue
Worcester 87161095590PCB Worceser 18 Ri 12/15/18/24
WorcesterCBI Range48012787161463320PCB 9/14 14/19, 19/24
Worcester28i48015487161463290PCB
Worcester241 Junior48077887483004840PCB Junior Range
WorcesterSBi7912548716146328015 SBi, 24 SBi
Worcester24148055087161209930Fan 241 RSF
Worcester28i48016387161216810Fan 28i RSF
WorcesterSi Mark 1148011587161048150Centrifugal Blower
Worcester15 SBi 87161214840Fan Assembly
Worcester28CDI RSF 87483002760PCB
Worcester24i RSF4804798716463000241 PCB
Worcester15/24 SBi79091187161567510Gas Valve 15/24 SBi - Honeywell
WorcesterCBi48122687161216990Cast Iron Heat Exchanger
WorcesterSBi Range 79167587161411870Front Facia SBi Range 15 SBi 24 SBi
Worcester1 RSF 241/281 87161410690Front Facia 241 281 RSF
Worcester241 RSF48058487161424130Gas Valve Tandem 837
WorcesterGreenstar 24 - 281 87161095390PCB
WorcesterGreenstar 35/37 CDi87161082120Heat Exchange Plate 20
WorcesterGreenstar CDi 87182252430Gas valve gas valve kit
Worcester 87161425000Expansion Vessels 10 Litre
WorcesterStamdard 771619108360/100mm Worcester Flue Extension
nope the boiler parts my cousin bought a massive amount parts from when plumbbase shut down and there just sitting in storage wasting away man so he just wanted them shifted Well in my garage as i had went tho everything. the amount of times he and i have bought parts for boilers when we have in stock so rather just clear it all out now
Reply to Plumbing + boiler parts massive list in the Plumbing Jobs | The Job-board area at PlumbersForums.net
