Discuss Poor valve operation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Is it just me or do others agree that these valves are pretty useless, when needed, ie taking washing machine out, never seem to close fully with resulting drips.
Morning. It is because people fit them and never ever move the lever until they need to isolate the machine. It is like a stop tap that hasn’t been moved for 10 years. Move it every once in a while and it will be fine.
Agree there but one can only point out so many times, specifically to my daughters, to run the stopcock a couple of times a year.:rolleyes:
If you want a decent one that will work
Lever valve and a 3/4 male iron :D
Reply to Poor valve operation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop and then occurs again. I have a little plastic bucket to collect the water, probably about 3 cups of water in a 24 hour period. I was doing some...
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and replaced it with new components from Nu-Heat but the valve is not working properly. The valve replacement seems very simple with 4 main components and some...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a steady stream without stopping. Seems to be coming from water heater but I cannot tell. It is cold water. When I turn off the main water supply, it...
Pritesh Patel
