Currently reading:
POTTERTON PERFORMA boiler that will not stay powered on if the gas solenoid valve is connected
Discuss POTTERTON PERFORMA boiler that will not stay powered on if the gas solenoid valve is connected in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a POTTERTON PERFORMA boiler that will not stay powered on if the gas solenoid valve is connected
I have changed the pcb and it did work for 1 day but now it’s failed again with the power led not staying on, and will only stay on if I disconnect the gas solenoid valve
The fan spins up fine but once I connect the gas valve the power led goes out
If I leave the boiler off for an hour or so It will sometimes run for a few hours before failing again
Do I need to get a new gas solenoid valve ?
Reply to POTTERTON PERFORMA boiler that will not stay powered on if the gas solenoid valve is connected in the Plumbing Jobs | The Job-board area at PlumbersForums.net
