Discuss Pressure relief valve leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tucker1
Hi people
I have a Saunier Duval Themaclassic F30E which has been releasing water from the PRV.
It was initially letting out a bit when the pressure got close to 2 bar but seemed to be ok all winter, after I removed and refitted it and also flushed out the whole system and refilled.
The other day it had not been on for a few days and was showing 0.9 bar so I topped it up but the pressure didn't really increase on the digital reading. The disconnector non return valve was also spitting water out of the drain hole at the bottom each time I tried to fill.
The PRV has since been dripping when it's running even when the bar pressure is below 1.0 bar now.
I have ordered a new PRV and a new disconnector for it. However, I have read a few threads suggesting the expansion tank may be an issue with such symptoms?
My only theory for ruling that out at the minute is that the pressure isn't high (0.8bar and it's dripping) and therefore the PRV shouldn't even be opening. But I just wanted to check if there's anything else I should consider.
I have wondered if the pressure sensor could be reading wrong or dirty and the actual true pressure is much higher, due to me opening the fill valve and it not seeming to do a lot?
I will change the two parts and hopefully it will cure, but just checking my logic is right and the expansion vessel isn't likely to be the problem?
unless your gas safe sorry to say you cant work/ fix on gas appliances
Hello tucker1,
Welcome to the forum.
First of are you gas safe registered ? If not you will need gas safe registered engineer to undertake such a job.
However, if you are you will be asked to provide evidence for the admin.
Regards, ron
if you are GSR please pm me,if you are not read the forum rules
Reply to Pressure relief valve leak in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days it's increased whilst cold...is this a regular problem.
PSxxxxxx
