Discuss Problem with hot water supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Colehurst80
I should be really grateful if someone out there could please help me (and my daughter!) with the following problem. For the past few weeks, my daughter's hot water (from the bath and basin tap, I think) has been dwindling, to the point where there is almost no water coming out and she is very worried that it will eventually disappear altogether. The cold water supply is OK, apparently. She is in a rented maisonette, which uses an old electric hot air system. She says the hot water supply from the kitchen tap is OK although I didn't think it was brilliant when I stayed there. Does anybody know what could be causing this and if it would be an expensive thing to put right.
Many thanks.
If it`s rented then refer the problem to the landlord is my honest answer.
Reply to Problem with hot water supply in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
