Discuss ProBoil hot water tap boiler leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
peedy17
I have a proboil 2x boiler for my instant hot water tap.
It has developed a leak from inside the casing. This is the 3rd boiler i have had now as replacements and all developing the same leak.
I live in a soft water area, any ideas what could be causing this or is this a known fault?
I have just had the same issue with the unit being replaced under warranty!
I dismantled the unit and discovered a plastic spigot on the Venturi unit had cracked.
This was the response from Abode:
From the images sent over it does look like the venturi has snapped which can happen due to a build up of pressure internal to the tank—this can be caused by a lack of maintenance, poor installation, or transit damage. As we checked over your install, we can rule this cause out.
Reply to ProBoil hot water tap boiler leaking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
