R
raffuk
On a condensing boiler is there anything wrong with terminating the copper prv pipe into plastic soil pipe. Both Condensing pipe and PRV have been terminated at nearby soil pipe.
Discuss PRV Termination in the Plumbing Jobs | The Job-board area at PlumbersForums.net
as eco says but requires a trap after tundish. do you have any pictures you can upload, carnt understand why your "plumber" has done this ?Thanks guys. If it did blow out, does it blow at a temperature that could melt part of the plastic soil pipe? Is it worth calling back the plumber to correct it, installation was done 3 weeks ago
would be best to put a tundish and hepvo valve in and use push fit not solvent waste.
editedwould be best to put a tundish and hepvo valve in and use push fit not solvent waste.
Reply to PRV Termination in the Plumbing Jobs | The Job-board area at PlumbersForums.net
