Discuss Pulsating hot water supply to shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Kmac
Hi everyone - wondering if anyone can offer words of wisdom.
I have a problem with the hot water supply to my shower. Its a bath mixer tap (compression washer type) with a shower head attachment - hot water is supplied by a combi boiler that also supplies 8 radiators. The central heating is fine and the hot water supply to both the kitchen and bathroom basin taps are fine. The boiler has recently been replaced and was working perfectly. We have very soft water and normal water pressure.
Intermittently, the hot water will rapidly pulsate from the shower head and there is a loud banging noise that goes along with it. When the water is pulsing, the whole water supply to the shower head pulses - it doesn't pulse hot/cold, it pulses water/no water. This is true even if the cold and hot are both on. I've tried to do some fact finding and this is what I have so far:
When the water is run through the bath tap (i.e. diverted from the shower head to the bath filler) everything is fine.
When the cold tap is opened and run on its own, everything is fine.
When the boiler is switched off and cold water is run through the hot water tap, everything is fine.
When the shower head is removed and the water run through just the hose, the problem persists.
When the shower head and/or the hose are changed to a new one, the problem persists.
The problem is intermittent but more likely to occur:
When the hot tap is turned on more fully/full.
In the evening.
Once it's happened, it happens every time the hot water is turned on. Only after a number of hours have passed (usually overnight) is it likely to function properly again.
If anyone has any ideas - please let me know. I'm hoping it's not a problem with the hot water line, because that run underneath the floor underneath the bath...
Reply to Pulsating hot water supply to shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
