Discuss pump capacitor problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gary80gas
Hi all,
I have a Grundfos pump with 240 volts, not jammed, runs each day for approx. 30mins-2hrs then stops. Capacitor looks ok but wire dropped out I put it back and pump running again 30min -2hrs according to owner.
Could this just be the capacitor needs replacing? I don't have capacitance reading on multi meter.
Where can you buy replacement capacitors? I looked online and hit brick wall. (2uf and 400volts)
Any help- thanks in advance
normally the cap is only used for start up if if its cutting out and tbh there not worth trying to fix unless its a special on just change the pump
I am not saying it is, but that can also happen to circulating pumps if they have magnetite in them. They often start when cold, but jam when they get really hot.
Motor windings do fail when hot also.
If it is capacitor, try Grunfoss themselves, or an electrical supplier
Suggests wiring breaking down or possibly bearings damaged causing drag / friction doubt it`s worth try to save imho.
I thought that but I'm sure when I said it once someone suggested a grundfos type pump used the capacitor as constant running speed or something??!
im sure these new modulating pumps have a constant cap as they need to keep changing there speed
so you might be half right havent had chance to take one apart/stripdown
Capacitors usually installed for current needed to start up pump, as running current is around 8 times lower. But will check it out to be sure.
Reply to pump capacitor problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
1K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
1K
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
