Snuky
Hello,
About one year ago I finsihed a two year evening course in plumbing, since then I have not managed to find any work so I am now starting to forget the basics.
The background
I have just moved house and the heting system needed a little work. The vent and feed pipe for the CH are the same pipe, They link into the system on the boiler flow pipe just after the pump. I have a Rad that is allways turned on to act as some sort of bypass. To get rid of this insanly warm room I thought I would change the vent and feed pipes to how they should be.
The question
At what point should the pump be placed in an open vented system.
Currently my pump is just after my boiler on the boiler flow pipe. The pipe work then runs into the cupboard with the hotwater cylinder, just before the 3 way valve there is two Tees the first goes to the always on rad the second goes to the F+E tank in the loft. THis pipe tees in the loft one to the feed and one to the expansion. Have I got to bring both pipes to a point before the pump?
The background
The question
