Discuss Pumped hot and cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've just fitted a stuart turner monsoon 1.5 bar twin pump in a friends house. Couldn't get a surry flange at the time so just came straight off the top of the cylinder with the vent and hot feed to pump. The hot and cold outlets downstairs are fine but its the shower and basin upstairs that doesn't switch the pump on when outlets are turned on. Here is the system set up - The property used to be a bungalow and had a loft conversion about 15 years ago so the cold water storage tank and f & e tank went up into the loft space. The cylinder was and still is in a cupboard downstairs and that where the pump also is. the cold on the basin and shower are fine. its just the hot wont switch the pump on.
It seems as if the pump isn't getting enough water flow to switch on but its working fine on the downstairs outlets
Any ideas what it could be ??
where is the pump situated in relation to the hot cylinder
Your shower head is probably close to, or above the level of water in the cold water storage tank in the loft.
most manufacturers will supply you with an aftermarket negative head switch.
this can normally be fitted in the shower ( air switch) but needs line to be run to the pump.
Hi all. What a complete dick I am. Customer had told me tanks was in the loft. It is yes. The F + E one. The 50 gallon cold water tank is in a void on the 1st floor level. Below the level of the taps and shower valve. No wonder it doesn't work. Now that explains why the existing broken pump had a pull switch in the bathroom to switch the pump on. Not really a problem because the pump that i fitted was one that i took out of a job and he had the pump and the work for free as he is a good friend. Maybe he will go buy a negative head pump now.
Thanks for all the quick replies though guys.
Note to self. Always check things. don't take it for granted from the customer !!
Reply to Pumped hot and cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
M
Hi, I woke up this morning with cold water (mains) from downstairs tap but no hot water from downstairs tap, and no water at all from all the...
Mike Young
M
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
