Discuss Pumped return worcester 18ri in the Gas Engineers Forum area at PlumbersForums.net
Hi all
I've got a customer with a kingfisher in a downstairs cupboard with gravity hot water and pumped heating. The cylinder has the vent on the flow to cylinder and cold feed on the return. I plan on installing an 18ri with an s plan kit and wireless cylinder stat. My question is if I pump the flow connection of the boiler and the flow of the cylinder it could pump straight over the vent. The only option I see to get the pump to pull on the cold feed is to pump the return. Anyone ever done this?
Cheers
Seal it or move the vent
Stnd set up for gravity hot water
Hi Shaun
Guy doesn't want to seal it. Combine the feed and vent in 22 on cylinder return?
No need to move the vent only option if he doesn’t want to seal it
Reply to Pumped return worcester 18ri in the Gas Engineers Forum area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
Silly question (and might already been asked 100rds of time) - I am specifying a circulation pump for the hot water secondary (circulation) return...
