Discuss pumped zone wiring in the Plumbing Zone area at PlumbersForums.net
F
fatboyray
help needed need wiring diagram 4 pumped zones all on stats and work alone but need boiler pump over run to work on atleast one of the zones thanks
Need more info (If you know the exact components, that would be very helpful):
1. Is each zone separately timed?
2. If yes, separate timer or programmable stat?
3. Which boiler (make and exact model)?
If the boiler uses pump overrun, then the pump will be wired directly to the boiler. So you will need an Automatic Bypass Valve fitted after the pump and before the zone valves.
Reply to pumped zone wiring in the Plumbing Zone area at PlumbersForums.net
Thought I'd attempt to outrank another forum. But I'm not sure my skills are there yet 🤔 😕 😅 Plumbing Zone forum. And contractor talk and...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
Is there anyway of testing electrically with a multimeter or any other way. Of testing that when you turn a room stat up it is creating a demand...
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
