Discuss Purging larger installations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pssst
Im just trying to dig up a reference to this....now due to the small volumes of typical domestic installations we would usually purge by relighting an appliance or using an appropriate fitting.
Obviously UP1/1A are the relevant docs for larger installations but is there actual quoted procedure which states what can and cannot be purged into an internal space . In short what is the cut off point by which you MUST use a purge hose and vent it direct to outside?
Anything over 0.035m3.
Can you quote a ref please?? I think back in the day a rough rule of thumb was that if the purge vol was 10% or less than the internal space then let it blow..whooshh..
Ige/up/1b for smaller domestic
............/1a as above
Yes i have copies of both UP1B and UP1A..can you quote the relevant section/paragraph no please?
No but if you read them cover to cover you will find what you need.
Reply to Purging larger installations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
