Discuss Purging? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all. If a inset gas fire is the furthest appliance from the meter what's the correct method for purging if the joints before the appliance are soldered? Obviously the idea is to crack a union but if there are no unions near to the appliance what is the correct method?
That's what I'm on about?
Yer I do. What I'm after is an opinion as to whether it is correct to purge from another appliance which isn't the furthest point. In the viper book it doesn't actually state it needs to be from the furthest poknt
Macka well done on putting this questions in the arms out of public view
The reason for so many questions is down to the fact my company don't seem to do anything by the book. So although I work with gas most days it's not always to the regs.
I did ask if I could use the fire and was told it would take ages to purge so they'd rather a union cracked. I know if I was at work I'd be told to just light the fire.
Open window Etc to outside , no smoking no using light switches etc and crack on
There should be a minimum flow rate to stop stratification within the pipe
it does take ages to purge on occasions however i wouldn't crack a nut on your test lol.
you did answer your own question tho nigh on tho you probably just need nudging in right direction more
Purge by ignition surely?
Reply to Purging? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I wanted to ask is there a function to remove air from a Baxi duo tec combi 24 HE A. If there is can some one kindly tell me the...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
Hi everyone, I've weirdly had two small kind of commercial decommission jobs come in today and i dont do this stuff much. At some point I've had...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
