Discuss PVC waste pipe for outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plumbers Merchant!Where do you buy your 40mm pvc waste pipes from? I'm struggling to find any.
Or do you just use the ABS solvent weld pipe and don't bother painting it? I haven't seen any painted!
I cannot find the forum feed for my question, so I'll ask here.
I have 50mm pvc condensate piping on an external wall from a recently installed boiler and I am totally unable to source any insulation to cover the pipes to prevent freezing in the winter - as happened last February!
Is there a wrap for external pipes or is there a 50mm internal bore insulation pipe?
Chris Whelan
Reply to PVC waste pipe for outside in the Plumbing Jobs | The Job-board area at PlumbersForums.net
