Discuss Question about sink plumbing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Good morning!
I'm replacing my sink and I have a question about the plumbing, hope you can help.
When the old one was removed I was able to add valves and resume normal operation for the rest of the house. You will see from the picture the piping coming from the main valve is doing a loop before it goes into the rest of the house. I was planning to simplify this but unsure if this is actually needed (as in reducing water pressure, etc.). Would you mind looking at the photo and telling me if this arch can be removed? I would do a straight line with a tee to feed the internal and external taps.
Much appreciated.
Yes you can simplify it but I doubt you’ll notice a difference
Reply to Question about sink plumbing in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I want to swap a K1 radiator with a P+, the same size on a combi system. Can i turn off both valves, remove the existing radiator, put the new one...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hi everyone, I got the water tested in my flat which has high chlorine levels and I am going to get a under the sink filter chlorine remover...
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone...
