Discuss quiz question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
feltham
Who here knows what the 5 catorgarys of water regulations are without looking it up on the net?
i was just thinking this the other day how many people knew at work.prob not even half.
I think so ...
1, 2, 3, 4 and 5!
Can't remember the names but something along the lines of:
Potable
Stored
Slightly soapy
Soiled and industrial
Heavily contaminated, excrement
Back to school if I've got these wrong :)
you have numbered the 5 fluid catorgarys.
what i ment was the water supply (water fittings) regulation 1999
ie misuse
just another 4 .
is this a college question? or just a curious one?
i would guess some of the answers as
lead free soldered fitting. removal of lead pipes
correct jointing pastes ie boss green
en/bs rated fittings
type/material of water tank storage
quality of mains water
let me know how i done
contamination
Erroneous measurement
misuse
undue consumption
waste
contamination
misuse
undue consumption
waste
well done mate i thought there would of been more people guessing
no not a college question just a question for you all
Interestingly, I don't think many Plumbers answer questions in a set form usually.
Most seem to tell, by looking at the job, whether its right or not.
Because I suppose by looking at the actual job, this gives them a picture clue as to what may be wrong. A bit like doing one of those spot the difference puzzles you sometimes find in magazines.
If for instance you seen an incoming water main with out a stopcock or drain off, you'd know it was wrong, but would probably have to look up the answer to find which exact water reg it contravened. :):):):)
Reply to quiz question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
