Discuss Rad sizing calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have to size a lot of radiators for a big detached house set in the countryside.
im looking for the best rad sizing calculator and wanted your opinion on what is the best / easiest to use.
thanks in advance
cubic feet of room multiplied by room multiplier gives you btu's. Very rough and ready, but rarely far off the money.
If you have a smart phone or android then theres an app called mr combi radiator calculator, very good app, i use it all the time and accurate,
Thanks, I need something where I can email the client my working out as he is a commercial surveyor and likes to know how you get to every decision. I'm looking for a good computer program, I don't mind paying for it as I will use it any way, rather than use an online freebie.
E/B
You should use a excel spreadsheet with all the 'U' values for that property, do it proper none of this rule of thumb,
and you need to use proper ACR, old houses a draughty places oh and before ermi jumps in what about insulation.
If you set up a spreadsheet you can use it over and over again just tweaking the "U" values for different properties
also at the end of the data divide the total heal loss by the floor area or the volume and it gives you and idea if these
rule of thumbs are anywhere near, sometime they are, and sometime not!
Good Luck
The real trade software is Hevacomp all bells and whistles, it cost ÂŁ1000s I have never seen a domestic one but there must be one, it will still
use a database or spreadsheet in there somewhere, you could write a MS access database but the spreadsheet is much easier.
Pace out every room, if the rooms are under 4 paces by 4 paces square chuck a 4ft single in, if they are bigger use a 4ft double........simple
Always seemed to work for my old boss in the eighties
Reply to Rad sizing calculator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Does adaptor exist? Hi, looking to move a rad, the original valves will be hidden behind a bath, so I was wanting to leave original valves in...
I have recently moved into a new house. We have a problem with the heating in a bedroom that sits above a garage. The garage is an integral part...
I am repiping my whole house and changing from combi boiler to a 30kW system boiler & 250Ltr or 300Ltr unvented indirect hw tank. Can somebody...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
Hey all, Looking for some advice. My mother recently had her boiler changed but in the process the water had to be turned on and off as you would...
