Discuss rad valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If the olive is going to be about 1/4" clear past the end of tail, then it will be fine, as nothing can go wrong with the olive. But if you want you could buy a Myson rad extension, which are all one piece, same as those supplied with rad valves.Yes its were the nut fastens up to the rad valve tail end had been first fixed but is 10mm out on one end. There is no play in the pipe so may have.to be a tail extension?
Thanks so as long as the start of the olive is 1/4inch past the end of the rad tail all should be well?
Reply to rad valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
