Discuss Rad valves with O-rings in the DIY Plumbing Forum area at PlumbersForums.net
Some RAD valves come with O-rings, whereas the majority do not and I just wonder if one is better than the other or whether it makes no difference whatsoever?
Reason I ask the question is that I have spent ages looking at valves and have settled on the ones in the link, but I’ve never used valves before with O-rings and so before I hit the buy button I just want to check with you guys: Valves
TIA
1. It doesn't really make any difference.
2. If you use the ones with O rings, the radiator surface where the O rings sit must be smooth. Very often they aren't.
3. There's nothing wrong with the ordinary sort. Its just a matter of wrapping sufficient PTFE tape around the threads to make a leak free fit.
4. The number of turns of PTFE depends on how tight the threads are without anything. Fairly tight, and you might start with 8 wraps, fairly loose and start with 15 to 20. In proportion for a different fit.
5. There are other sealing methods:
5a. Loctite 55 cord - allows for some (max 1/2 turn) backing off. Not needed for radiator tails.
5b. Loctite 577 or Flomasta Pipe Seal. Liquid sealant. Very easy to use, gives a good seal, expensive.
Appreciate the detailed response.
When using ptfe on rad valves, is it worth adding a dab of something like Hawk White, or is it unnecessary or maybe a pain if you ever have to remove the valve again? I already have Hawk White, as well as hemp, but not used either yet.
Reply to Rad valves with O-rings in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, Have got an old 60/70s PVC soil stack, the Toilet is going into a Hunter branded socket which has an old O-ring design (quite flat with 3...
Hi. I have a Vado summit bath tap with hand diverter. Recently the diverter stopped working and after liaising with Vado, I managed to remove...
Hello Plumbers I’ve replaced a 540mm high cast iron rad with 740mm high, like for like but still a 20mm valve extension was required. All was...
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
Hi All I'm planning on replacing a couple of rads soon as they are far too small for the size of the room causing the room to take an age to heat...
