Discuss Radiator half hot and half cold in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all.
I noticed this winter my living room rad only get hot in the top half.
Radiator is 1600mm(DP SC) double panel single convector.
System was flushed just last year.
Both flow and return values are fully open and don't stick.
Boiler is serviced each year.
Baxi combi boiler about 8 ton9 years old.
Pressure is 1.5bar.
All rads(7) have been vented in the house.
I've tried turning all other radiators off which did heat the rad up, but once others are back on, same again.
My bolier is in the loft with the living room rad and kitchen rad(1800mm DP DC) being the furthest from the boiler. Kitchen rad get hot with no issue.
Any advise to trybfix this issue.
Many thanks.
Mickey.
Reply to Radiator half hot and half cold in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
