Discuss Radiator Trouble Help Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Evening. Looking for some advise and help.
We have 2 radiators on the ground floor that refuse to get hot. (They are warm just not hot the same as the radiators on the first and second floor).
We have had them replaced under advise from an engineer and they are just the same. Water doesn’t seem to be circulating properly.
What do I do next?
The plastic pipe is hidden in the walls so not an easy fix to replace the piping. Been told the pump is powerful enough so that’s not the issue.
Are they on their own feeds or teed off other rads
What do I do next?
Close the other raditors and see if there is any difference.
Email back with results
Sounds like a balancing issue then
Remove rad do you get flow at both valves
Reply to Radiator Trouble Help Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Hi All, We renovated our house in 2019 and put in completely new plumbing system and piping including new boiler and 9 radiators. Off those, there is one radiator in the living room which does not heat up at all. I have tried balancing myself and also had a professional come in to balance it...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at the timer panel, it works but it also heats up all the radiators above ground floor. I have to close them individually to stop this. The rads aren't...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6 other radiators and 2 bathroom towel radiators are just normal valve s. We live in a 4-bed, 3 storey house, as converted loft. Common problems were...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
Desperate for some help! Be a life saver of someone can help as suffer from a high intolerance to noise. Moved into new house 1940s (copper pipes) and having serious issues with banging pipes only when central heating is on. Not when running taps We have a wall in living room that has stop tap...
