Discuss Radiators boiling but no hot water from taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 108976
We have a coal fired Parkray room heater, running 6 radiators. They are all red hot but there's no hot water from the tap. What should I do? I'm quite nervous about the back boiler blowing up.
If the water from the hot taps is cold then there is a problem with the gravity circulation side around the indirect cylinder (I am assuming this is your set up). It could be as simple as lack of water in the system or an air lock but it could also be a blockage so best to call a heating engineer to confirm the route is clear.
Get an immersion put in it will save you loads in the summer
you will get the instal cost back really fast...I would not ask your landlord just get it done.
centralheatking
Housing bum is great Rob, I will ask them. We had a new kitchen put in the immersion switch was taken off for the new splashbacks, I'll moan at them to gimme a new one.
TY all for your help, the plumber has been now. When I asked him what had gone wrong, he said he wasn't really sure but it was sorted now :D
Reply to Radiators boiling but no hot water from taps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have hot water, tank for hot water why is the hot water boiling hot from tap,and shower, We are on a schedule for hot water via our hive app 2hrs in morning 2 hrs in evening Any help be much appreciated
PSxxxxxx
