Yes! Would agree depending on boiler type. Its favourite to be either trv pins stuck, pump impeller stuck or possibly gunk in the system.
Try a magnet on the pipes?
If you have got loads of magnetite in the system it will probably stick.
But if you have got a conventional system, just drain, flush out and put new inhibitor in system. You can if you want, get descaler and flush that through as well. All probably well cheaper than a power flush.
All this power flush stuff is expensive for what it is.
But if you have a modern boiler with a plate heat exchanger it may be as well to get a power flush. The problem is the internal water ways on plate exchangers are very close together and it would seem obvious they would block easily.
So the system really does need a good clean out including the boiler.
But then if you have the time you can do it yourself, just do each rad by themselves and flush through with a hose. Same with boiler.
Don't forget to look up the advised number of flushes both hot and cold to give the system. I'll post a bit more if you like?
Good Fortune
