Discuss Radiators only luke warm if hot water is on in the Central Heating Forum area at PlumbersForums.net
Radiators are only getting luke warm if hot water is on but boiling hot if hot water is turned off. It’s either hot water, warm radiators or warm radiators hot water cavy seem to enjoy both anymore. We had the system professionally power flushed in Feb this year so what could the problem be. Thank you.
I’m guessing you have a hot water cylinder and an s-plan or y-plan setup? If not, can you tell us what system you have?
I’m also guessing you mean hot water warm rads, or hot rads warm water?
Good morning and thank you for your speedy response.
We have an emersion heater upstairs in the airing cupboard and a cold water tank in the loft. Downstairs we have a gas boiler (not a combi boiler) for the central heating and hot water.
As for the s-plan / y-plan question I’m so sorry but I haven’t a clue what that is! How do I find out please?
Thanks again. xxc
An S-plan is x2 motorised valves independently controlling heating and hot water, or both on together. A Y-plan is one motorised valve, also known as 3 port mid position valve, which still does the same, just one valve as opposed to 2 and usually a higher failure rate. The way to find this out is to go to your airing cupboard and just after the circulating pump (usually) should be the valve(s). If you’re unclear still, take and upload a photo of airing cupboard and we’ll be able to tell you.
Reply to Radiators only luke warm if hot water is on in the Central Heating Forum area at PlumbersForums.net
  • Solved
Hi, I am looking for a bit of advice. Our Gledhill hot water tank was installed incorrectly 18 months ago and has been sending bubbling hot...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
G
I've just bought a 3-floor house with a gas boiler on the ground floor and hot water tank on the middle floor. When I switch on the hot water at...
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
