- Messages
- 15
Some rads get very hot and some get warm .if I screw the lockshield valve in a little on the hottest ones ,will this make the warm ones get hotter ? Thanks
Discuss Rads different temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Half a turn open from fully closed. You may have two or more turns from fully closed until you can't turn the spindle any more, but most of it is "wasted space" as the valve will be fully open at about 1½ turns from closed.doitmyself , is it half a turn from fully closed or half way open between fully closed and fully open ? thanks
Reply to Rads different temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
