Discuss .....Rads mounting..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ShaunCorbs
Super Moderator
Staff member
S. Mod
Subscribed
Solutions
Not finished so will update
Things you have to do / figure out / make to fit rads onto things
Anyone guess where's this is getting installed on
Did you have to weld that frame up? If so, what was the weapon of choice?
No made it out of uni strut but migtronic is my go to 3 phase aswell butter arc form and power even on lower settings
i bet that was a pita as its cast
I’ve acquired a clm500 Clarke lathe, that I pick up next week:D
ive got an old belt lathe in bits that im trying to get around to restore
Yes it was, trying to weld cast to plate.. the amount of contamination in the cast, made it difficult. Also trying to keep the power low enough not to melt the cast into a molten lump.
did you pre heat the block?
I’m getting this lathe, but I really don’t know much on using it. I’ve been hammering ‘how to’s’ on YouTube :D
need a decent set of cutters / tools, start with scraps from the local scrappy and practice
Reply to .....Rads mounting..... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
