Discuss Rayburn 480k cooker problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rebecca Hammond
My Rayburn 480k keeps sending out strong fumes in to the kitchen and then soon after locks out. The boiler side is fine, it has just been serviced, had a new thermostat, new motor, new flexible tube to the cooker side as it had a big hole in it. The photo cell keeps getting melted, the engineer replaced it just after christmas and it only lasted 9 days. I replaced it two days ago but it is already going wrong again, fumes and cutting off. It has a balanced flue terminal and the engineer says there is a hole in the flue extension. Could this be the problem? Also he says that some of the ceramics had flaked off inside, he doesn't know why. Also the cooker seems to like working when the boiler is on. Any ideas as he seems a bit stumped and it is beginning to cost a lot and the Rayburn is still not fixed!
As Simon said turn off ASAP and get someone else to look at it. Something clearly isn't right.
Have a customer with one of these. I installed it 6 years ago and it's been fine up until last year when he had similar issues! Rayburn have basically stripped it down replaced all the ceramics burners you name it and it's still smelling and not working correctly.
There is a history of this sorry to say!
Your best bet is a reputable local company. Down here we have spillers who are pretty switched on but apart from that nobody is interested!
put back together and seals havent been placed correctly. re pcells melting, some new rayburns need extra bit on oven side to keep them clear of the heat or they melt, very hard to find, aga dont stock the part, had to order off abco and get ecoflam to provide me with a part no
Reply to Rayburn 480k cooker problems in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Rayburn will not turn off at the end of the third cycle each day when set to 'heating and hot water', even though the green 'on' light is out.. Switching to 'hot water' only, turns it off. Engineer called and replaced the control panel and mid position actuator - no effect. It turns off OK at...
I have an old Modena 80 E combi boiler that is randomly short cycling on windy days. The burner goes out and re-ignites within a few seconds and continues to burn for between five and forty seconds before stopping again. Under normal conditions the boiler works fine but as soon as it gusts over...
I have a 499k rayburn with a balanced flue. When we turn the cooker side on it works for a while OK, it could be OK for a few weeks then it will blow out and the kitchen smells of kerosene. If we try and restart it it won't come back on for a while. But then we just press the restart button and...
I have a fault on my Rayburn 499KB. The boiler side fires up fine when cold. Once its hot, or oven hot, it will not fire & goes to lockout. Cooker side is working fine. Has Ecoflam twin burners. I have had the burner out & replaced damaged PEC, leaking capacitor and both burner nozzles. Have...
1K
Hi there, Big gas noob here. We got a gas cooker installed a few days ago, and the gas cooker is now sitting quite far away from the wall (3cm which sounds like not much but throws the balance off of the kitchen), which means there's a large gap now between the cooker and the wall, but it now...
