Discuss Re-presurising boiler not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, hope someone can help?
After bleeding radiators I need to re-pressurise, I have tried fully opening both taps on the loop but nothing happens! The taps I'm referring to are circled in red on the picture. Any ideas or I doing something wrong? Thanks, Rich
yes, i believe the mains is permanent but i'm no plumber my self so not sure, could it be that there's another tap for the main feed that needs turning on (possibly elsewhere from the picture)? I'm definitely turning those black knobs the correct way, thanks
The link in between the two tap heads can be removed but I very much doubt that anyone ever does and if they do they'll never find it again, it's in the same place as the fitting and service manual.
Same as a normal filling loop then. I remove and cap externals on a service. Then on the service next year, guess what?
Reply to Re-presurising boiler not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
