Discuss Recommendation on Vailant combi model and a few other items. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Z
Ziad
Seasons Greetings to all.......please can you give me you're expert opinion of brands and models etc for my following requirement (will be doing a complete replacement of my 20year existing boiler/CH system in Jan)
1) Which Vailant combi model would be suitable for a 2 bed medium sized ground floor flat, 2 sinks, 1 x towel rad, 4 x double thickness rads (shower is electric). Its a poorly insulated flat with cavity walls (and marble flooring throughout)...so good CH is a main priority.
2) Radiators & TRVs - which quality brands/model would you recommend - am going for double thickness rads rather than a single long run in each room.
3) Room Thermostat - ideally would want a wireless one
4) Do i need a gas pipe upgrade? - the existing Valiant combi has been there for approx 20years and the main gas inlet into the flat is approx 2 - 3 metres away from the boiler. Do the new boilers need a larger (diameter) gas pipe feed? If so, what mm pipe?
5) Boiler Filter - would like a filter that has both mechanical and magnetic filtering ability.
6) Live in a very hard water area (in west london) - what type of water softner product would you recommend to be fitted to the incoming cold mains? Preferably a low maintenance one.
7) Is it advisable to powerflush the existing system prior to dismantling & replacing it so as to get all the crud out of the pipework?
Im just doing this a my own little research before i go out for quotes. Many thanks in advance of all advice.
1) if you don't have a bath or shower a 24kw might do.
2) I use stelrad rads and Honeywell trvs ( rads need sizing by your engineer)
3) Honeywell room stat, I would advise wired over wireless if you can
4) gas pipe upgrade, don't know as not on site, needs to be done by engineers on site
5) I use magnaclean pro 2s
6) combi mate,
7) it's more than advisable it's essential, cleaner could be put in a week before then a hot power flush done.
Would be a good idea if you got some heating engineers round to discuss your needs and give you a quote.
As above. Get your quotes then come back to us. You're getting a touch too in depth.
Reply to Recommendation on Vailant combi model and a few other items. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
