Discuss Remote control shower not working bypass? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So I've got a remote controlled shower. I don't know if the damn remote is just shot or something more is wrong with it. But just curious if the remote was shot is there any way to bypass the damn remote and still turn the shower on!?
and re bound the controller with the remote ?
Reactions: rpm
do you know the make and model? should be on the main control unit
urc50200r00 Mira shower remote
Upon reading about it they say there could be water damage. And looking into it further looks like they don't make these remotes anymore unless you guys know better where to obtain one. If so any help would be great
Thank you all for your replies.
You can't bypass the remote it operates the pump, no signal from remote no pump.
You could try the showerdoc
The Shower Doctor - Showers, Spares, Accessories & Advice
Does it look like this?
Reply to Remote control shower not working bypass? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Hi All, Looking for some advice on my little bathroom project. I took the bath out. I got a shower jacuzzi thing. The base has 2 wheels in the corner. Do I assemble the unit first attach water and elec, and slide the very heavy unit in on the two wheels? Or do I get the base in the corner and...
