Discuss Removal of thermo cartridge in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Would anyone be able to advise how to remove the thermo cartridge from these shower taps ?
The cartridge has a notch in it which means it can't turn.
This is a square shower set, and Im not sure the make,...maybe Victoria Plum ?
If you can advise on the manufacturer name, then that would be great.
Many thanks
Mike
Reply to Removal of thermo cartridge in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi - I'm a rank amateur DIY'er with plumbing, with practically 0 skills & I know next to nothing about it, but a few weeks ago our concealed...
This is driving me bonkers!
I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early...
I need to replace the shower cartridge as no cold water is getting through. Do I need to remove the faceplate to access a nut? The plate has been...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work...
Hi - I've got a quarter-turn cartridge that I'm trying to identify please - 35mm x 58mm. It's about 25 years old and uses square profile o...
