Discuss Replace combi - new flue needed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Glaflyer
Newbie here - just found this forum so I hope someone can help.
I have a flat with a 5/6 year old Saunier Duval combi gas boiler which causes continuing problems. I have been loking into replacing this with a new more reliable boiler.
I had a visit from a local firm to look at it. He said that to install a Baxi boiler would need a new flue. The existing flue runs horizontally from the boiler through a "box" which is part of the ceiling of a bedroom to an outside wall which is six stories above ground level. So the work would need to take down part of the bedroom ceiling and would need scaffolding up to the 6th floor to access the outlet. The flat is in a modern block built some 5 to 6 years ago. So the work would be disruptive and expensive.
Is there any type of boiler I could use which would minimise the disruption and expense of replacing the existing flue?
Thanks in advance
Martyn
Hi and welcome,
"old Saunier Duval combi gas boiler which causes continuing problems"
No surprises there then!
So what you are saying is that the current boiler vertically flued ?
Unless there is a suitable location on an outside wall that will permit the boiler to be sited there then you will have to site the new boiler in the same place and install a new vertical flue at the extra expense I'm afraid.
Difficult to advise without seeing the property of course :)
Oh and dont forget the new boiler will be condensing so you need to make sure there is a suitable drain/waste for the condensate to run into.
Thanks for your quick reply.
No the flue currently runs horizontally from the cupboard with the boiler, through the bedroom (along the ceiling) to the outside wall (6 stories up). The building is 8 stories high.
I had thought that a flue was a flue was a flue -- but apparently not!!
If I can't use the existing flue its going to be a major expense
Martyn
I see, all flues are different I'm afraid and boiler specific. From what you have said it looks like you are going to have to endure the disruption if you want to change the boiler.
As said no flue is the same,also the new regs state that the flue must not be enclosed ie "boxed in" they should be able to be inspected throughout thier entirety. can you not put the boiler in a different place?.
and more still - the new boiler will have to be installed to manufacturers instructions which supercede the gas regs. no manufacturer will allow you to join their boiler to a different boilers flu system.
Reply to Replace combi - new flue needed? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was...
