- Messages
- 10,442
Should be as close to the boiler as possible mate (shouldn’t it)Doesn’t need to be
Discuss Replaced PRV and still leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Doesn’t matter aslong as there’s no valves on the boiler / between the boiler and prv
I suppose if the pipes from boiler froze in severe weather (highly possible if boiler is in garage or an attic), then a remote prv could end up being isolated and no use
Best option if I’m honest. Ask around for a recommended engineer. I’m inclined to say try a different firm.Thanks for all your replies, I will get some one to take a look
On this instance though Shaun. It makes no sense to put the PRV where they have when they have fitted the external vessel next to the boiler. They cannot use the excuse of not having an external wall. It’s a garage, it will have at least 1.Should have a frost stat and that wouldn’t make any difference anyway as unless it’s inside the boiler would be the same
Think of a standard heat only boiler where’s the vent connection / tee normally in the airing cupboard
Unfortunately we cannot say. You will need an G3 registered engineer to tell you that.Just one more thing, the boiler has had all components completely replaced, all the PRVs and
The hot water tank expansion vessel have been changed in the last two years.
The only two things that have not been replaced in the past two years is the red expansion vessel next to boiler and the actually hot water tank itself, could it be the hot water tank itself gone wrong?
The pressure in the heating doesn’t rise when off it drops.Yes it could in theory as it is an old enamelled steel type which I bet has not had the anode replace. If the heat exchanger has rusted the higher pressure domestic water could be leaking into the heating water. As per other get a good G3 engineer in (& disconnect that filling loop as per Water Regs).
I know what you are saying, but even on an open vented system, I always put a prv on the system, - and straight off the boiler pipes. Normally only oil systems, but also some gas.
If an open system feed and vent froze in the attic, the prv would be needed
Safety valve is leaking all the time?The pressure in the heating doesn’t rise when off it drops.
Reply to Replaced PRV and still leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
