Discuss Replacement pull-out shower hose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
Ed_r
Hi I bought a replacement shower hose for a pull out shower.
It has a male connector end which attaches to the water supply. But the new one appears to be 1/2 inch when the original appears to be 5/8 inch in diameter.
The websites do not seem to specify which suggests a standard size which I dont have. Is it better to get a connector (if so where?) or should I buy a new hose at the right size, (if so where?)
I would be grateful for anyone steering me in right direction/
Are you saying the original one is bigger than the replacement? If anything I would have expected it might be 3/8" but can't help with 5/8" sorry.
Hmmm that's an interesting one! Hopefully someone will be able to help you :) Good luck
Reply to Replacement pull-out shower hose in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a brand new, unboxed shower/wet room screen from KRION purchased from Porcelanosa UK. It is the Attica 1 model, as shown in the attached picture from their catalogue. Like on this image ->...
Sebastian T
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
Hi, I'm looking for a water pump to pump water from a storage tank at a constant 3 bar pressure. It's at a campsite I run that's at the bottom of a long, steep hill. We struggle with very high and often fluctuating (around 7 bar) water pressure, which wreaks havoc with our water heaters. I've...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
