Discuss Replacement Pump for Wilo Gold 50 Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Was wondering if anyone could advise a good value replacement for the willo gold 50 pump , looked at so many now i am confused .
Wilo Yonos 1-5 m 130mm width pump will replace it.
You can get much cheaper pumps including versions of the Wilo under a different brand name.
Grundfos ups2 15-60 will fit also
Yes I have been looking at that or the 6m as this is what the Wilo site advises the 6m yanos seems a good price at wicks , just didn’t know if the cheaper ones are false economy .
The heating system is becoming a bit of headeach ,
3 port valve is having issues , known about that for a while , pump has started leaking from the bleed screw for that last few days after bathroom fitter was up there.
So have decided to change it all in one go get only pump left to order
Thank you for your reply
I had a brand new Wilo from screwfix, iirc it was extremely noisy and didn’t flow well, I rang their tech helpline - a very nice chap, told me it shouldn’t happen and to take it back. I did and fitted a Grundfos. :D
A lot of those pumps in your link are being sold under various names.
They are a clone of the old Grundfoss and total rubbish.
Only time to consider using one of them is if you were selling your home shortly
The new digital displays on the willo just seem to me more things that can go wrong. I’m not a believer in over complicating a simple pump.
The display is handy for setting the pump and confirming it is running at chosen setting and wattage, showing the variation (on variable setting) of both when system zones and rads close.
But agree with you, all these electronics in a hot pump just results in short lifespan
Reply to Replacement Pump for Wilo Gold 50 Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How do I decipher Wilo pump numbers? As an example what is the difference between a WILO ST 20/6-3 P and a WILO ST 20/7-3 C or a WILO ST 25/7-3 P...
Hi all, I'm trying to source a replacement pump for my heating system, I suspect the current pump is an older version that has been superseded...
Hi, I’m looking to find a replacement Collector circuit pump for a ground source heat pump. This is the pump on the brine circuit. The pump I...
Wanted a new shower pump equivalant to a Branston Varispeed 50 After 12 years my shower pump has stopped working and it looks as though this type...
Hi. Can anyone help me get into this tap? I have them on the bathroom sink and bath and 2 out of 4 are dripping. I've have had two plumbers in to...
