M
mosscliffe
I would like to replace my very old Honeywell Room Stat. I do not know the model number, but it is square and has a large dial and that is all, except the temperature variations between ON and OFF seem far too large.
I would like to fit one of the new programmable room stats and leave my Horstmann 425 Coronet on the 24 hours setting.
I was thinking about the Horstmann DTR2 ProgrammableThermostat, as that seemed quite flexible and most importantly had a 1 Hour setting and was also quite cheap.
I will have to use the original wires to the Honeywell Room Stat.
My question is - will I be able to wire the DTR2 stat with the existing wires to the Honeywell stat?
My original plan was to replace the Room Stat with a Wireless Programmer and then use a wireless room stat, which I could move as required, but that seemed to be complicated and I would have probably needed more wires than I had available. If this is possible, I would appreciate any advice.
Richard
Richard
