Discuss Replacing Grohe wireless shower control unit in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello
I need to replace my Grohe Geotherm shower cubicle mounted control unit.
Its around 17 years old but replacements seem to be available
The main hot / cold water control unit is in the loft, I think its working ok
How do I get the replacement cubicle control to connect to the loft unit wirelessly ?
Also the small remote has stopped working, not too worried about that
TIA
If you search online for the manual of your particular model, you should find the info you need.
I don't know if I've got the correct Geotherm model in the example below:
I assume the 'base unit' is the bit in your loft!
Reply to Replacing Grohe wireless shower control unit in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking?
This originally happened about 12 months ago and has happened 3-4 times since.
It’s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all,
I’m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. I’m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
