Discuss Replacing old thermostat for Nest in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
The Nest Heatlink requires a live and neutral supply.
Your existing thermostat is wired to control the switched live to the boiler. There appears to be no neutral present, as if there was it would be wired differently.
It will need a new 3-core plus earth cable to be run from the Nest Heatlink to the boiler.
I don't know if the mains wiring connections to the boiler are accessible without removing the casing, you may need a gas safe engineer to do this.
However if the current thermostat cable goes to an accessory or wiring centre, rather than directly into the boiler, you may be able to reconfigure the wiring outside the boiler.
Also the mt10 needs removing / removing the plug so gas safe engineer required sorry to say
Reply to Replacing old thermostat for Nest in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
