Discuss Reviving a Tap: Stubborn Tap Head in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rayleigh
Hi
I have trouble with reviving a leaky tap. the tap head just wouldn't come off with an adjustable wrench. (It slips off the wrench.) Would a Ring Spanner be of more help?? What are the other things I can try?
Cheers
Ray
a deep socket set might do it
do you have a set of grips or stillsons?
Get your self a good set of pipe/water pump pliers/grips will do the job
I have just got a standard pliers which hasn't got much grip at all. What kind of grips should i be getting? water pump pliers or mole grips?
Reply to Reviving a Tap: Stubborn Tap Head in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm...
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
1K
Hi all, I have an issue with our shower's hot water. The shower is operated using two separate taps for cold and hot water. When the hot water tap...
Please can you help. I’m trying to replace the cartridge on our monobloc kitchen mixer tap. I’ve found the secret hexnut and removed the handle...
4K
