Discuss Riello pressure gauge extension in the Oil and Solid Fuel Forum area at PlumbersForums.net
magicno1
Would any of you know where or if you can get spare sealing washers for the pressure screw or is it new extension?
cheers
Chris
I was going to say why not try Grant, its who I did my OFTEC with a long time ago and they've helped me with spares in the past.
I've tried finding a part number online but can only find one for the whole extension kit unfortunately.
Two choices, either buy a few kits and replace the whole lot with your normal mark up price or buy one, remove the washer and see if a local nuts and bolts company to you have them or can make them up for you. We have one of those companies in my town and they've helped out many times with various requirements.
Reply to Riello pressure gauge extension in the Oil and Solid Fuel Forum area at PlumbersForums.net
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a...
I have a SIP space heater and fitted a new matching spec oil nozzle as part of a service on it. I wanted to check the pump pressure with the new...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi guys, few years off doing the work but I like to plan. Can a soil stack be rerouting away from the house, over an extension roof? Reason to...
