Discuss Riello rs180 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gasmanrob
Been warned today I'm going to look at one of these next week with intermittent lock out. It's bolted to a viessman and has a gas train I've seen it in passing but never paid it any attention. This will be my first time solo on such a beast and was wondering if anyone had any similar dealings with them/common faults I could tick of first. Apparently it will light on 2nd reset and run happily for anything from an hour to a week.
thanks in advance. GMR
Lovely and short there jc. Is that a common issue or just a previous issue you've had?
billy the manuals are all there in about 17 different languages with print as big as the cheap adverts in the Thompson local..
They do but I usually find the fault Rob's described is down to the IP.
I'm not totally sure it is. I only know/guess what it is as I took a peek in the manual when passing through to the hw service valves back in December. It looks identical to that although I don't recall the triangular unit on the right hand side of it.
Reply to Riello rs180 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
