Discuss Rimless Toilet - Flush not reaching front of the bowl in the USA area at PlumbersForums.net
Hello All,
I'm trying to install a rimless toilet and I just cannot get the flush to function as it should. Here's a video of what's going on - the water doesn't reach the front of the bowl.
I've raised the issues with the supplier and after sending videos and pictures of the set up, they sent me a new toilet... which still doesn't work!šŸ¤¬
Here's my install (as you can tell i'm a DIYer! šŸ˜‚). I've got the cistern as high as I can. I've even tried blocking the overflow pipe to try to get more water in the cistern. (The cistern / fill valve / flush valve all came as a package with the toilet)
And the flush valve is set up as shown below...
Does anybody have any idea as to what might be going on? Since neither of the toilets work I'm starting to think I've got something wrong with the install.
Andrew
Problem with rimless toilets is you need force atm you donā€™t have much because your flush pipe is so short in the 2ā€ end and itā€™s a 90 d bend which isnā€™t helping swept would be better but still not great
So cistern needs to be higher maybe look at a different type ?
Is there much water left in the cistern after the flush?
That doesn't seem a full flush.
With the flush valve out, block the hole in the bottom of the cistern and let it fill to normal level, then let the water go.
After the flush there's a couple of centimeters of water left.
I've tried letting it fill and then quickly pulling the flush valve out but that doesn't seem to make any difference.
There doesn't seem to be anything wrong with the install.
You would expect the flush to be better than that.
Contact the supplier and as for a refund and try a different brand pan & cistern.
Reply to Rimless Toilet - Flush not reaching front of the bowl in the USA area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
