Discuss RINNAI E110CN Low Output Temp in the DIY Plumbing Forum area at PlumbersForums.net
Hi. Couldn't find this anywhere. My Rinnai e110CN intermittently and now permanently acting like it's 40F outside. It seems to be stuck in efficient mode with water temp at 115-120F instead of 165F. It's about 8F outside. The result is temp dropping in house. It did this a few times and it corrected when I pressed boiler on/off button (off then back on). It doesn't return to full flame when I disconnect outside temp sensor either. Burner is firing - just not hard. Feels like it must be a sensor giving it bad info. Thoughts? Thx in advance.
Reply to RINNAI E110CN Low Output Temp in the DIY Plumbing Forum area at PlumbersForums.net
We are a few months into our Viessmann Vitodens 100-W 19KW Heat Only boiler and it is working fine. We replaced an old 1999 Baxi. Our house is a 2...
3K
Hi, My combi-boiler has just given up heating the house and basically only delivers hot water. While in central heating mode it heats up and stops...
Hi I have recently had a Worchester 15i Regular boiler installed, it comes with honeywell control and thermostat also. Its suddenly developed a...
2K
Hi folks. Sorry this is a long one. I'll try and keep it organised. Son has just moved into a purpose built (2013 ish) 4th floor apartment as a...
6K
Evening All, Hoping some plumbing/heating engineers/other knowledgable folk on here might be able to assist with some questions about my new...
4K
