Discuss Roofing course please in the Gas Engineers Forum area at PlumbersForums.net
lordyjordy111
Morning
Does anyone know a good course for roofing. At the moment we use a roofer to do the roof slate when we do a vertical flue but I am changing jobs and will now need to do this myself. Obviously only need a course that covers this if one exists....
Cheers
It was covered in the C&G plumbing course but that was making your own using lead which is a very rare skill these days. Never done one in real life since college though.
If it was me I'd be asking fellow trades if I could shadow a couple with them, maybe - if your old roofer will also be losing out, pay him out of your pocket to show you how to do the first two or three.
Cutting a slate or two and fitting a flashing kit doesn't really need a course of its' own unless I'm underestimating the job.
Also done in british gas apprenticeship till 1976 includeing all plumbing leadwork wipe joints and lead dressing never done a slate though did loads of wiped koints in the 70's and 80's
Morning
Cheers
Roofing esp. patching does not require any course itā€™s common sense. Most lead slates etc are pre formed off the shelf items. If you want to learn how to join lead (it was traditionally plumbers work)
Just go buy some different codes of lead and a dibber (dressing tool) and have a go itā€™s great fun.
I was taught properly so can do snow boxes, down pipes and make all the fancy acanthus leaf decorations but basically taught myself. Centralheatking
[automerge]1581697766[/automerge]
Oh forgot to mention I can do decorative roses Etc. But only Lancashire ones no money in white ones
Lol Chking
Thanks guys for the reply. It's not the lead work as said I buy these pre formed. Its the working on roofs. Ie what ladders to use and how to tie off etc. Just wondered if there was a course. Doesn't sound like there is.....
Reply to Roofing course please in the Gas Engineers Forum area at PlumbersForums.net
  • Sticky
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
